I would like to trade my 89 240sx coupe for an ae86. The car is an auto and has the rare 2 tone sea foam paint job. Car is sitting at 166,000 miles but the speedo no longer works, I would guess the car is at 170-175,XXX. The car is not perfect and does have a few issues. The ac no longer works due to a pulley that froze up. I simply took the belt off. Head lights stay up, I have read this is an easy fix all you have to do is replace the headlight switch, the hud doesn't work again I read its an easy fix, simply soldering in a new resistor or something, the back light on the cluster doesn't work and yet again they say the fix is simply changing a small white box know as the tcu. I am not sure of any of this as I haven't tried. The biggest problem is the auto tranny is starting to slip. I was just gonna swap it for a 5spd. It honestly isn't that bad as I still dd it to work. Someone told me it is some type of filter but again, I have no clue. The only time it really does it is after backing up and putting it in drive it takes a while to fall into drive. Other than that the car is pretty solid, No known rust, the interior is pretty clean, I would give it like an 8 out of 10. After market head unit, header, exhaust, megan suspension in the rear, I believe the front may be cut springs, car is my dd and has not left me stranded or anything. Great fun little car, It's just not what I want.
76 celica in the back ground =)
There she is again
Factory phone???
So yea, let me know what you got.
Best ways to reach me or either email or text.
Text- 706-699-6994
Email-
Tj_saxon@yahoo.com
