222d
Not sure where you get 5VZ from.
I believe the post in this thread is correct that it was originally meant for group S with a 1.2 liter motor then they stepped up in preparation for group B to the 2 liter predecessor of the 3SGTE.
http://www.alltrac.net/phpBB2/viewtopic.php?t=34246If you look at some of the pictures it looks like they pretty much chopped the passenger compartment out and added a tube frame front and rear end to it along with custom body panels.
I am not a big fan of the front end but do often daydream about doing the same and add tube frame front and rear with a big motor. That would be a pretty good platform for the Twin turbo EZ36 build I want to do on an AW11. I want to do it mid engine RWD with the engine in front of the trans and a blockoff plate on the back of the trans but you could flip it around and go rear engine AWD.
