ae86 sr5 to 4agze
- AE86_DRIFTER_
ae86 sr5 to 4agze
hi im new to the 86 world and have very little knowledge on motors and stuff like that but i recently bought a ae86 sr5 hatch and i want to put a 4agze in it and i was wondering what are the steps on how to do the swap when i search the web all i get is gts to 4agze no sr5 to 4agze can someone please help thanks
Its all fun and games when on the straight aways... but once you get to twist and turns the laughter turns to tears
Re: ae86 sr5 to 4agze
You would be better off going SR5 to NA 4AGE then NA to turbo once you get the kinks worked out.
Turbo will give you more potential with less cost and less hassle in the long run.
- AE86_DRIFTER_
Well I kinda wanna put a 4agze to get a factory look I know sounds wired but I just want a step by step guide on how to put a 4agze in a sr5
I just did his swap but from a 4age to a 4agze...not from 4ac to 4agze...you would probably just need to do all the wiring as if you were doing a ge to gze swap and swap over the dizzy and flywheel from the 4ac..not sure though since i never had the 4ac motor
http://www.86garage.com/forums/viewtopic.php?f=3&t=3791 here is the guide from 4age to 4agze...you would probably need to do the sr5 to gts wiring first and then use the wiring guide....also make sure that the motor mount brackets are the same as the GTS and will fit on the gze motor...do you know what type of transmission you have?
- AE86_DRIFTER_
A stock sr5 transmission i bought this car from a 80year old lady this car is 99% stock the only mod I did so far was a radio lol
if it is a T-50 transmission then you should be okay...https://sites.google.com/site/ncalae86/resources-1 that is a good resource page for ae86's...check out the sr5 to gts link on there just to get an idea of what you need to do lol
Jeff Lange
All AE86's have the T50*, SR5 and GT-S. The bellhousing is the only difference, with the clutch slave on the opposite side (due to the exhaust being on the other side).
(* Unless it's an automatic)
Jeff
Jeff
- AE86_DRIFTER_
no its a 5speed lol
For a small bump in power flip the air filter lid. It lets a little bit more air in and will slightly help gas mileage
1984 Corolla SR5.....banana on wheels
Buddy Club Spec 2 Over axle, T3 Test Pipe, T3 Bomber Bar, T3 Ultimate Rear Brace, Enkei Apache 2 wheels, (Weber carb and Cam not installed)
Cheap, good or fast.....pick two.
