SOLD FS: rebuilt GTS T50
Markx
Postby Markx » Wed May 21, 2014 12:55 pm
Sold
$300 for transmission. $50 core charge if you do not supply me with another T50. (this means $350 if you don't give me a transmission back).
Recently rebuilt T50 (less than 500 miles) with new brass synchros (aftermarket), and new Toyota input, output, and speedometer seals.
Transmission is in good condition, shifts great, no leaks, no abnormal noise.
All bearings, gears, etc are used with unknown age/mileage.
Comes with GTS bell housing. You do not get release bearing and related parts.
This transmission is in the car right now, and you will be able to road test it to verify good operation. There is no warranty. You will have to wait a few minutes for me to remove trans if you buy.
Speedometer gear works, but is not correct ratio for my car.
If you supply me with a speedometer driven and drive gear, I will swap these out for you at no extra charge. (Again, no warranty, so make sure you have correct parts).
If you want me to install trans into your car, please message me for further details.
Also for sale is the clutch/pressure plate in the car right now. It is used. Pressure plate is heavy duty ACT T019 http://www.advancedclutch.com/t019
Clutch disc is a performance street type or unknown brand. One side is normal disc, the other side is puck. It has a purple center. This may be ACT as well.
$25 for both.
Cash only. I live in Corona CA and will not ship or go to you.
edit:
If you don't need the GTS bellhousing, I can give you an SR5 bellhousing for $25 off the price.
All parts are from '85-'87 GTS/SR5 cars. The only difference in SR5 and GTS is bellhousing and speedometer gear ratios.
Speedometer will work in either GTS or SR5. However, it will read the wrong speed if your ratios are off.
Price is $350 if you do not give me a transmission in return.
I do not know the mileage of this transmission, or even what car it originally came from. You can assume that it's 30 years old with a million miles. Does it matter? You get to drive it before you buy it.
If you drive a modified Corolla and drop the clutch, it will eventually break. I know this from 10 years of breaking crap in these cars. That is why I said NO WARRANTY.
If you want a transmission that will last forever, dont' abuse it. If you want to abuse it, get a w58.
booooyet
Re: FS: rebuilt GTS T50
Postby booooyet » Sat May 24, 2014 3:29 pm
Need a transmission. Text me 9O9.201.6II7
