Firstly, I've tried facing the T-Stat housing both directions, and neither one will seem to clear the alternator. Is this a case of wrong alternator? Wrong coolant neck? Wrong radiator hose? (The radiator hose I bought is Gates #21065)
Secondly, (I don't have any pictures of this), I had the synchros in my T50 replaced, and while it was apart, I was playing around with the speedo gear, ensuring I had the proper GTS one, and not an SR5. I noticed that when I have the trans in gear (on the bench), and spin the input shaft, therefore the output shaft, the speedo gear is not turning. I looked in the speedo hole, and the output shaft worm gear seems to be possibly off centered or something, however it is between two clips, as it should be. Any ideas why my gears are apparently not meshing? or is it spinning so slowly I can't notice it turning?
