![Image](http://www.nonstoptuning.com/images/Braille/B106C.jpg)
BRAILLE Lightweight Batteries are used by drivers in the following series:
• FIA WRC
• FIA Formula Racing
• Formula Drift
• Xtreme Drift Circuit
• Speed World Challenge Series
• SCCA ProRally Series
• SCCA Regional and National Racing
• NASA Touring Cars
• NIRA
• NOPI
• Battle of the Imports Drag Racing Series
EIGHT REASONS TO CHOOSE BRAILLE:
1. Excellence
Great all around performance for small displacement motors. Using AGM racing technology, Braille Batteries have the highest PCA and CCA, more than any other battery in each weight class.
2. No Spill, No Corrosion, No Maintenance
Technically registered as a "sealed valve regulated" design, this patented technology completely eliminates acid spills and corrosion on terminals. This design is environmentally safe does not need filling and maintenance. Air shipping approved.
3. Exclusive Dual Terminal Design
A Braille Battery exclusive! This feature allows the battery to be mounted in a variety of positions. It is designed to accept racing, powersports and automotive terminals vertically and horizontally.
4. Stainless Steel Terminals
Stop loose battery connections with our robust stainless steel threads. These heli-coil design threads allow higher bolt torque and help keep your battery connected even in high vibration environments.
5. Exclusive Brass Auto Terminals
Included with every Braille Auto Battery are patent pending high quality brass SAE terminals. Designed to distribute the electrical load into and out of the battery. Designed for high amperage, high stress use of racing and audio competitions.
6. Green from Start to Finish
We employ a manufacturing process with the highest concern for the environment and quality. Recycled lead, plastic and stainless steel ensure we'll have a future to race towards.
7. Solid Top Lead Connectors
Shaken, not stirred - From 6 "G" NHRA drag launches, to 4 G cornering loads in Indy this design holds the internals firmly in place.
8. Performance Certified - Fully Charged
Every Braille Battery is individually tested and certified before shipping, eliminating DOA batteries. Fully charged and ready to install at time of shipping.
SELECT YOUR BATTERY AND PROCESS YOUR ORDER WITH US HERE:
http://www.nonstoptuning.rpmware.com/br ... 10160.aspx
Thanks all!
MIKE @ NST
