So I have been working with Hasselgren for a while to try to offer their products and services to my customers. They are very busy so it has been slow moving forward but I do have a short list of some things that are available to me.
I am working on getting more info such as compression ratios and design on the pistons, available cam profiles and so on and I will update as I find out more. I will also add parts to the list as they come in. In the meantime if you are interested in any parts hit me up and I can look into it for you.
I can also get access to their services such as block reinforcement, porting and so on.
Used Parts
USED STANDER ATLAINTIC CONTING RODS ( Reconditioned )
Used Atlanitic double value springs
New Parts
81.mm JE Pistons + .002 Coated
81.mm JE Pistons + .002 0.005 Coated
81.mm Mahle-X -1 pistons + .002
Carrillo Long conrods New
HRE custom 1800 cc billet crankshaft used low mileage
HRE Carrillo connecting rods new for 1800 / 1600 conversion n
Custom cam lifters ( DLC ) coated ( Limited phase 1 )
HRE Custom cam shafts hard face , will need dlc lifters
intake
exhaust
DAYTONA PROTO- TYPE USED & NEW PARTS
Complete 5.0-liter turn key Chev Daytona prototype engine
bore size 3.910 bore sizes . ( Equipet with Mahle pistons,carillo rods
jesele valve train ,rockers , lifters , timing belt drive , maton push rods,
callie crank shaft , excel dyne values , daily dry sump pan& pump , total seal
rings ( Dimond coated ) stwart warner water pump , ) 555 hp as is though with
fuel injection manifold change & cam sahft These engine are capebul of 600 + hp .
Less engine Harness .
Matrix Garge now has access to hasselgren parts and services
Re: Matrix Garge now has access to hasselgren parts and serv
if you can get the wrist pin retaining clips and rings for this piston set, I'll buy them. Been trying to contact them for years to get these things with no success.
So you aren't looking for the pistons but just the rings, wrist pins and clips?
that is correct.
chohdog wrote:that is correct.
Are there any serial number or other markigns on the pistons? I suspect I would have better luck going straight through JE if we can get them the right info.
I suspect even if you got me basic specs like ring groove widths, wristpin diameter and length and clip style I could probably source them.
I would try that first then I could try Hassle gren if all else fails.
Shoot me an email if you want me to look into it.
http://www.matrixgarage.com/content/contact-us
im looking for 20V BT piston set, with rings. stock rebuild, would like to go with 81.5mm size.
looking for aftermarket pistons that might be stronger, as my number 2 piston has a cracked ring land.
RW Bliss wrote:im looking for 20V BT piston set, with rings. stock rebuild, would like to go with 81.5mm size.
You should email me.
I can definitely get you setup with something that will suit your needs.
Contact info is here.
I do apologize, I only check this section every once in a while.
