brake light not working
Brake lights not working , all fuses are good, but the stop Fuse isn't getting any power ?? Any suggestions ???
						Re: brake light not working
I think I may have had a similar problem.. does the button mechanism thing that sits behind the actual brake pedal work? Is it getting power?
I'm not sure yet , I've gotta check it out again tomorrow ... but regardless , I should still have power at the fuse ??
I would double check all the connections first and make sure the contacts are good.
*Edited to avoid confusion in the future
Thanks for your help , ima check that out ...
There should always be power to the fuse according to the wiring diagram.
Download the wiring diagrams and check for yourself: http://www.aeu86.org/technical/ae86-manuals/
Muh bad haha, thanks for chiming in Grant
