20V BT OEM flywheel question
s3cf
Postby s3cf » Thu Aug 15, 2019 11:25 am
Hello
To install 20V BT OEM flywheel into an AE86, all I need is the clutch pressure plate and disc from an AE92 GTS, correct?
Thanks
Re: 20V BT OEM flywheel question
Postby jondee86 » Thu Aug 15, 2019 9:26 pm
Correct. Should be 210-212mm outside diameter clutch disc. Use the
AE86 throwout bearing and spigot bearing (if you have a 20V engine).
s3cf
Postby s3cf » Fri Aug 16, 2019 11:12 am
^^^ thanks Jondee86
