4age 16v shim retainer
- speedmaster
i have under bucket shims and no retainer to hold it, so where can i find this? thanks
Visit my FB fan page at https://www.facebook.com/speedmasteracing
Re: 4age 16v shim retainer
speedmaster wrote:i have under bucket shims and no retainer to hold it, so where can i find this? thanks
I don't understand what you are looking for.
The retainer holds the valve spring in place. The retainer has nothing to do with shim under buckets. You need the actual shim under bucket to be able to run the shim under shim.
- speedmaster
How do on hold the shims in place under the bucket?
speedmaster wrote:How do on hold the shims in place under the bucket?
you need either the proper retainer to run shim under... the retainer holds the shim until the bucket is lowered...
OR the shim fits over the valve stem and fits the valve stem like a tiny cap
- speedmaster
So its a special valve spring retainer that I'm looking for?
- speedmaster
The shim is flat unlike 20v shim
Oh I haven't seen that style before. In that case you would need a retainer like OST posted. No idea where to find something like that.
- speedmaster
That's the problem. Thanks bro
Ford Zetec E top hat shims fit but they need to be ground to size.
The bottom of the shim needs grinding so that it sits on the valve stem rather than the valve collets (keepers) and the top of the shim needs grinding to get the correct clearance.
http://www.burtonpower.com/shim-160-x-6 ... fz215.html
- speedmaster
Wow thanks. I go have a look
- speedmaster
totta crolla wrote:Ford Zetec E top hat shims fit but they need to be ground to size.
Wasnt what I was looking for. But thanks
- speedmaster
Something like this
Are those your actual parts ?
If so then these people can supply a 'button' type shim that fits inside the spring retainer:
http://www.arrowprecision.com/14-shims
- speedmaster
totta crolla wrote:Are those your actual parts ?
this is the actual thing
In my opinion you would be better off just using the top hat type shims, I use them and have had no issues whatsoever.
The shims you already have are likely to need grinding to fit and on top of that you will still need to source the 16 spring caps.
Any head that those cams are fitted into will need further machining as the lobes will not clear the head casting.
- speedmaster
totta crolla wrote:In my opinion you would be better off just using the top hat type shims, I use them and have had no issues whatsoever.
the shims that like the one from 20v?
The grey part in the picture posted by OST above:
http://www.maruhamotors.co.jp/parts/05060690.jpg
Fit all of your followers without shims, fit your cams, measure the gap, deduct the clearance required then order them pre-ground.
The caveat to this is that there is a 'pad' on the under side of your followers, can you post up a picture of the inside of one of your followers ?
- speedmaster
totta crolla wrote:The grey part in the picture posted by OST above:
They look a lot like my followers and if the pad thickness is the same on all of them you are probably good to go.
Looking at the link below you can find both top hat adjusters for 20v engine and shimless buckets with varying thickness pads for adjustment.
Check to see if your pads are all the same thickness, if they are different thicknesses then you probably have a set similar to those pictured here:
http://www.k1motor.net/AE101%20AE111%20TRD.htm
- speedmaster
oldeskewltoy wrote:speedmaster wrote:How do on hold the shims in place under the bucket?
any idea where to get such retainer?
- speedmaster
totta crolla wrote:They look a lot like my followers and if the pad thickness is the same on all of them you are probably good to go.
my problem is to hold the shims under the bucket
- speedmaster
good to go as in without using the shims?
you may need to have them made....???
I'd check around before that... call Supertech, SI, Ferrea... find out if they have the retainers you need....
- speedmaster
oldeskewltoy wrote:you may need to have them made....???
would i be better off wit 1szfe lifters?
speedmaster wrote:oldeskewltoy wrote:you may need to have them made....???
I was going to suggest the 1SZ buckets
http://club4ag.com/tech-data/valve-lift ... 16v-4a-ge/
Or Catcams
http://www.catcams.com/engines/camshaft-setup.aspx
- speedmaster
jdm86gtz wrote:speedmaster wrote:oldeskewltoy wrote:you may need to have them made....???
Or Catcams
those lifters are hard to come by
You may already have 1SZ buckets but you need to measure the thickness from the top of the bucket to the underside pad.
If some of the measurements are different then the chances are you have 1SZ buckets or similar.
If you have 1SZ buckets all you need to do is install the correct sized ones on top of the valve, no extra shims are necessary.
- speedmaster
totta crolla wrote:You may already have 1SZ buckets but you need to measure the thickness from the top of the bucket to the underside pad.
Just the clearance issue. But the 1sz lifters are not easy to find
speedmaster wrote:totta crolla wrote:You may already have 1SZ buckets but you need to measure the thickness from the top of the bucket to the underside pad.
quite true.... very tough to acquire... a sizing set is recommended, this is 8 of the thinnest 13751-23030, and then checking the clearances and ordering the correct set based on repeatable accurate measurements. I went through this in OST-026 - viewtopic.php?f=7&t=10783
- speedmaster
Maybe try asking supertech if they have such retainer. It's a waste not to use the toda shims
