Heater core solutions?
BlackStar
Postby BlackStar » Fri Apr 05, 2013 9:25 am
The heater core I bought from autozone doesn't fit, what does everyone do for a heater core? One from a different car? I posted a WTB add, yet haven't gotten any leads. I would like to put my car's interior back together.
DJManila
Re: Heater core solutions?
Postby DJManila » Fri Apr 05, 2013 10:53 am
BlackStar wrote:The heater core I bought from autozone doesn't fit, what does everyone do for a heater core? One from a different car? I posted a WTB add, yet haven't gotten any leads. I would like to put my car's interior back together.
Some one in the build thread had his heater core re done, I just gotta think who it was.
Formerly known as seanperia
BlackStar
Postby BlackStar » Fri Apr 05, 2013 11:50 am
problem I have is that on mine, one of the 90 bends where you attach those hose is....broken completely off. I also don't have it.
overspool
Postby overspool » Fri Apr 05, 2013 5:21 pm
I work at O'Reilly auto parts. I've been working with Murray on finding the appropriate part. So far no luck.
BlackStar
Postby BlackStar » Fri Apr 05, 2013 8:10 pm
the autozone one was so close, its just that the flaps in the air router box don't completely close. the hose hook ups were in the right spot and it fit in the air router. so close!
overspool
Postby overspool » Sat Apr 06, 2013 1:57 am
Not bad. The O'Reilly one had one of the hose hook ups, pointing the wrong direction/upside down.
BlackStar
Postby BlackStar » Sat Apr 06, 2013 5:46 pm
as long as the hook up clears the engine, and fits through the show in the firewall, Whats the beef? Just running more heater hose?
BlackStar
It could be my 4AC has more clearance in that area then the 4AG
mikeyee
Postby mikeyee » Sun Apr 07, 2013 1:47 am
hit up yellow pages for a local plumber that can braze the pipe back to the heater core.
or find some machine shop that can take care of it for you.
Not You
Postby Not You » Sun Apr 07, 2013 7:32 am
If yours is just clogged and old soak it in CLR and let it sit for about 2hrs. If the pipe ends came off then you will have to take it to a plumber or rad shop to have it brazed back into place. Those Advanced and other cores fit like crap and dont work. You can also take it to a local rad shop and they will replicate it for you if you like.
BlackStar
Postby BlackStar » Sun Apr 07, 2013 11:40 am
good suggeestion , i may have to do that. mine flows fine, its just one of the hookups is broken clean off
overspool
Postby overspool » Sun Apr 07, 2013 2:56 pm
I want an OEM fit heater core, something I won't have to modify.
overspool
Postby overspool » Sun Apr 07, 2013 3:00 pm
Not You
Postby Not You » Sun Apr 07, 2013 3:28 pm
overspool wrote:google found something...
http://www.partsgeek.com/gbproducts/WC/ ... Qgod2AoA_Q
And you know for a fact it works? Cause I'm not sure if you have been reading but none of the "replacement" cores have fit properly.
BlackStar
Postby BlackStar » Sun Apr 07, 2013 8:03 pm
The one from parts geek doesn't look to bad, the pictures looks right. The picture does. I'm not sure If I would part with 100+ to find out.
overspool
Postby overspool » Tue Apr 09, 2013 12:48 pm
It's not going to fit perfect, but it'll be better than nothing. The 86 FX heater core fits in the slot (you have to fight it a little bit to get it in), the blendoors will open all the way, but one of the heater lines faces the wrong way.
yogi59fifty
Postby yogi59fifty » Tue Apr 30, 2013 8:40 pm
I bought one through kragen/orielley if you want the part number I can email it to you, I went through trying to find the correct one for days, my car sat over a month waiting for them to send me the right one. You can email me.
Postby yoshimitsuspeed » Tue Apr 30, 2013 9:33 pm
I can repair cores if someone can't find someone local they trust.
I could look into making replacements if there was the demand. It sounds like yogi found a solution but I thought I'd put it out there in case.
