Spark plug wires
Spark plug wires
I have a 4agze in my ae86 that I've converted in turbo - anyways I bought spark plug wires and they barley fit to my distributor-( not long enough ) does anyone know where I can get a good set ?
Re: Spark plug wires
The GZE distributor cap ends point up, right? The ae86 4age distributor cap ends point out, and therefore longer.
My turd of an 86
20v swapped 86 write-up
My turd of an 86
Yes I am using the 4age distributor any suggestions other than replacing the distributor ?
Which one? Fwd or rwd distributor?
My turd of an 86
My turd of an 86
Rwd . I wonder if I can just switch out caps ?
That's odd, wires should be long enough. Yes, the dist can be swapped out. So your cap looks like this?
http://imageshack.us/photo/my-images/36 ... 79by4.jpg/
My turd of an 86
My turd of an 86
Mine is a diffrent cap - I would post a pic but don't know how
Yours is fwd, go buy wires for a 1985-87 Toyota corolla GTS. They are about 2-3" longer as you can see in pic.
My turd of an 86
My turd of an 86
The only issue with that is the actual plugs are taller than the GZE ones . The GZE plugs are short and stubby
Right, forgot that. To fit under the cover.
My turd of an 86
My turd of an 86
Yup very frustrating .
I have an MR2 distributor with TRD AE86 GTS plug wires. They are a mile long. Does your distributor look like this? You can use the stubby plug wires with it.
Knockoff Crew member #0001
Yes I does look like that - I wonder what's the diffrence between the two ? The cap looks the same but point forward for my timing .
