Here's more info on the car
- 4AGE AE101 20V Silvertop 1.6L Factory ITB setup.
- Engine has a custom wiring harness built by Phoenix Tuning to run the Blacktop AE111 Electronics for running Open throttle bodies on a Silvertop.
- Engine was rebuilt using factory parts as a refresher, new bearings, rings, all gaskets, TRD MLS Headgasket, water pump, oil pan, timing belt and components, and essential tune up parts have been replace with brand new parts. The motor has ZERO miles on it as it sits. Engine was built in 2010 has about 1 qt of oil in it to keep things lubricated an addition to the assembly lube. Cylinders have oil in them to keep them lubricated and I have been spinning the engine manually once a month to ensure that.
In order to get the engine running you will need the following: ecu, engine bay harness(car has one but id replace it with an uncut one) and, full exhaust.
- Transmission: T50 5 speed manual with 97K purchased used in 2010.
- Clutch and Flywheel: Fidanza Aluminum Flywheel, ARP bolts, Centerforce Dual Friction (stage 2) clutch and new throwout bearing. Needs a slave cylinder, master cylinder is brand new.
- Rear End: Car has the SR5 welded Drum rear end in it. It is a Solid Axle rear end.
- Included with the car is a GTS disc rear end that has a Kouki AE86 LSD unit with axles. All backing plates, and calipers are included, as well as the GTS rear driveshaft section.
- Has a brand new GTS gas tank and straps with fuel pump and sending unit mounted. Has brand new fuel lines, stainless steel braided lines front to back with built in fuel filter
- New custom routed brake lines for the front, GTS proportioning valve and brand new brake master cylinder are installed. Included is a 5 piece SS brake line kit.
- The hood, flip up front headlights, and side markers and OEM grill are included. You will have to run the engine bay harness as it is not installed in order to hook all of this up.
- Rear lights are also included. Original to the car, has some minor cracks but still usuable.
- Car has no bumpers, oem or aftermaket.
- The interior is pretty much gutted. I have the HVAC system, dashboard support, and dashboard harness. New ignition lock cylinder and key. All the factor floor sound deadening has been removed. No seats.
