Help with possible first build
Be nice to others.
Abcdefranklin
Postby Abcdefranklin » Sun Jan 05, 2014 10:23 am
If all goes well I should be buying my first project build. First off ill start by saying I'm not the most mechanically inclined person but have always had a passion for cars and have wanted an AE for as long as I can remember. So here's a few of my dilemmas. First off I'm a perfectionist/ one of those do it right once kinda guys & I've wanted an AE basically my entire life I'm not sure if I want to take on a project or find a bone stock ae. Its an sr5 to gts conversion so a part of me just wants to buy a clean gts already. Taking on projects scares me, if I was ever halfway done with something I could never just give up, to me if your selling a project there's a reason you don't want to finish it. I do love the thought of a project though as I will be replacing every bolt I can something that wouldn't that possible on a working ae. Also im not sure if the silvertop itb setup is exactly what I want also. Doing some reading it seems that they're usually around 150 horse. I'd like something 250-300 is this possible N/A? I also get worried if the engine is still good etc as the car isnt running theres no sure fire way to double check. Im planning on going to check it out this week so if theres any tips/hints or things to look for please, please let me know. Sorry if this is a stupid thread and sorry if I sound like a whiny kid I'm just a little nervous and the perfectionist in me is getting the best of me. I just want a dope AE and hopefully I can build that with the help of this forum. Thanks everyone
Here's more info on the car
- 4AGE AE101 20V Silvertop 1.6L Factory ITB setup.
- Engine has a custom wiring harness built by Phoenix Tuning to run the Blacktop AE111 Electronics for running Open throttle bodies on a Silvertop.
- Engine was rebuilt using factory parts as a refresher, new bearings, rings, all gaskets, TRD MLS Headgasket, water pump, oil pan, timing belt and components, and essential tune up parts have been replace with brand new parts. The motor has ZERO miles on it as it sits. Engine was built in 2010 has about 1 qt of oil in it to keep things lubricated an addition to the assembly lube. Cylinders have oil in them to keep them lubricated and I have been spinning the engine manually once a month to ensure that.
In order to get the engine running you will need the following: ecu, engine bay harness(car has one but id replace it with an uncut one) and, full exhaust.
- Transmission: T50 5 speed manual with 97K purchased used in 2010.
- Clutch and Flywheel: Fidanza Aluminum Flywheel, ARP bolts, Centerforce Dual Friction (stage 2) clutch and new throwout bearing. Needs a slave cylinder, master cylinder is brand new.
- Rear End: Car has the SR5 welded Drum rear end in it. It is a Solid Axle rear end.
- Included with the car is a GTS disc rear end that has a Kouki AE86 LSD unit with axles. All backing plates, and calipers are included, as well as the GTS rear driveshaft section.
- Has a brand new GTS gas tank and straps with fuel pump and sending unit mounted. Has brand new fuel lines, stainless steel braided lines front to back with built in fuel filter
- New custom routed brake lines for the front, GTS proportioning valve and brand new brake master cylinder are installed. Included is a 5 piece SS brake line kit.
- The hood, flip up front headlights, and side markers and OEM grill are included. You will have to run the engine bay harness as it is not installed in order to hook all of this up.
- Rear lights are also included. Original to the car, has some minor cracks but still usuable.
- Car has no bumpers, oem or aftermaket.
- The interior is pretty much gutted. I have the HVAC system, dashboard support, and dashboard harness. New ignition lock cylinder and key. All the factor floor sound deadening has been removed. No seats.
Re: Help with possible first build
Postby jondee86 » Sun Jan 05, 2014 12:47 pm
Welcome to the forum :) That's a big project you are looking at right
there !! Stripped shell re-build, so you have to find every part and put
it back in the right place. And you will need to be able to read electrical
wiring diagrams and figure out which wires go where.
But having said that, there are pretty simple vehicles, so the mechanical
side of things is straight forward. From the description it seems that
most of the important parts are there...engine, gearbox and complete
GTS disc brake rear end. And looking at the engine pic I would be
inclined to think that the engine has been re-built as described. All the
work that has been done... new parts... indicates that the owner has
been doing quality work.
This project is going to take a lot of hours to complete, and when it is
done and the engine is humming... it will still only be making 150hp.
200-250hp N.A. is not a realistic goal for a 1.6 liter engine. You need
at least 2 liters... or a 1.6 with a small turbo. A well built 4AGE turbo
engine will give you 250hp all day :D
But whatever you decide, all the information you will ever need is in
this forum. There are build threads that will walk you thru most of
the conversion details, and if you get stuck... just ask.
Abcdefranklin
Postby Abcdefranklin » Sun Jan 05, 2014 3:04 pm
Thanks so much for the help jondee! I know it's a huge project but ive been looking at it as if its not which is bad. im acared pf putting everything back together im very ocd what if stuff doesnt go where its supposed to! How hard is electrical?
I figured I wouldn't be putting out good numbers with the silvertop I've been looking into the f20 swap because I wanted to stay N/A. although i do have the silvertop already so I'm thinking about going turbo because the 150hp sounds disappointing. Haha.. Also the bay is tubbed so idk if that'll interfere running intercooling piping.
IF I did go turbo what would I need exactly? I'm not sure if I would need to swap internals or anything like that. I tried searching but couldn't find much.
Postby jondee86 » Sun Jan 05, 2014 6:46 pm
Since you would already have a solid 20V engine in place, I'd suggest that
you investigate adding a small turbo to the 20V. Being a high compression
engine, success relies on having very good control of fuel and ignition...
and selecting a suitable turbo. This board member yoshimitsuspeed has
had good experience with this kind of build, and I have no doubt he will be
able to point you in the right direction.
You will need custom intake and exhaust manifolds, and as intercooler tubes
are mostly custom made, that should not be an issue. You are already up for
a BT ECU, so you can offset that against the cost of a fully programmable
ECU. If, further down the line you decide you want more power, then you
can always change to low comp pistons and a bigger turbo :mrgreen:
Electrical can be daunting and frustrating, if you don't know what each wire
is for. However, if you have some patience and study the diagrams, you
can figure it out. The BT wiring is never going to be plug n play with the AE
wiring, so usually better to know what the wires do, rather then trying to
match colors. I believe Dr Tweak might do a custom engine harness
for the BT ECU, but if you go aftermarket, you will need to wire it yourself
using the ECU suppliers harness.
To be honest, I think that when starting out you should just concentrate on
getting a running car. Call that "Stage One". Then, you can be driving while
you plan your next upgrade/engine swap etc. A lot of projects are stillborn
because people aim too high and invest too much money. Then, when they
realise that they don't have the skills, time or energy to complete, they
discount the project off. Possibly what is happening here ??
Postby yoshimitsuspeed » Mon Jan 06, 2014 3:04 pm
Hey, welcome to the boards.
You are definitely looking at a big project there if this is something new to you. That said, if you have the sticktoitness you will learn a lot.
I would have to say wiring can be one of the most frustrating things to do if you are the least bit OCD. There are really two sides to wiring. Getting all the right wires to all the right pins, sensor and gauges and then figuring out how to rout it so it makes sense and looks good. The former is about as simple as basic math, it's either right or it isn't. The latter on the other hand can be challenging at first but it gets easier the more you do. That said, trying start with a mess and trying to make it work can be more frustrating than starting from scratch. My AW11 wiring is still a rats nest because I wanted to get it running and it probably would have taken another 20 hours to get it pretty good, more to get it perfect. I plan on fixing that when I switch over to MS3.
You could always skip that part and pay MR220v or Tweaked to build the Harness and then you just run it and plug it in.
I agree with most everything else Jondee86 said. IMO the only reason to pursue more than 140 WHP out of an NA 4A is because you are racing in a league with rules that limit you to that choice.
On the other hand 300 reliable hp isn't that hard to do with boost.
150 HP can actually be pretty entertaining in these little cars. Many may get the bug for more at some point but it should be enough to put a smile on your face.
I am a huge fan of high compression low boost. My current setup is a stock 11:1 compression blacktop running about 7 PSI on the GZE ECU. My car was originally GZE so that was a little easier for me but in your position I would definitely jump straight to aftermarket engine management. None of the 4A ECUs are impressive enough to go out of your way for.
The Silvertop has been run at 10-15 PSI several times on stock internals. It's delicate at that so you would have to be very careful in your tune but fortunately you can start low and work your way up as you get more confident. 10 PSI doesn't sound like much but at 10.5:1 compression and starting out at 150 HP that 10 PSI will gain you quite a bit.
You might start by reading these
http://matrixgarage.com/content/yoshimi ... oing-4a-ge
http://matrixgarage.com/content/project-japanarat
SlideSexy
Postby SlideSexy » Wed Jan 08, 2014 9:46 am
Ah, I have spoken to the PO of that car.. Friend of a Friend. So seeing how you must be in RI/MA we have to make it a point to meet up sometime!
As for the PO.. he was sort of a perfectionist as well (thats the vibe I got from speaking to him). Has previously owned Silvias SR & RB swapped, Built Hondas and other cars. I guess he just didnt want to deal with the AE anymore. He and both our mutual friend said it ran, I myself personally believe it.
Tips for you:
If you want to stay NA to make 250hp.. 20V isn't the answer. If being 4 CYL and well balanced with the possibility of upgrades is for you, F20C is a great way to go. But you will have low torque and will cost over 5k. If a V8 isn't a problem, go 1UZ. You can find them in junkyards, come with forged internals, and first gen starts with 256hp/260lb tq. Swap will roughly cost 3k.. done right.
Do remember though, with the swaps like F20C and 1UZ, you will need/is highrecommended to upgrade your rear end.. these AE86 rears cant hold much. Unless fitted with aftermarket Diffs and axles. For this, you can go with 3 Main options. First being the most expensive, but most responsive. Your GTS rear, with Weir performance axles, and an aftermarket LSD. Second being the hardest to find (Especially in our area.. my dad has been looking for the LONGEST time) 78-81 Celica Supra rear end. Bolts right up with TechnoToyTuning's 4 link kit. Holds over 350lb tq iirc. But the rear alone is $500+. Then theres the trusty old Ford 8.8 which requires the most fabrication. Something like one side of the housing needing to be cut and shortened to fit. Then your old brackets from your rear must be cut and welded on to the 8.8s rear. alot of work, but will hold themost power and has alot of aftermarket support!
ANYONE CAN BUY A NEW CAR. IT TAKES A TRUE ENTHUSIAST
TO BREATHE LIFE INTO AN OLDER ONE.
Abcdefranklin
Postby Abcdefranklin » Fri Jan 10, 2014 4:23 pm
Thanks jondee, I agree with you 100% I like to get ahead of myself. And since I've never built a car thanks for bringing me down a little bit haha I should just focus on "stage one"
@yoshimitsu thanks so much for the links those write ups really help especially as I don't know too much. I'm not sure how high I would want to go with compression, im not sure what cams i would need. And idk how much boost I would want to run. I guess I'm just a little confused on all the electronics ill need, basics what ECU would you prefer? I wouldn't want to get the BT or GZE as I feel ill swap it out down the road I'm very buy the best now kinda guy just to get it over with.
@slidesexy yeah man from RI! you? and eh idk man!! I looked up the f20 swap that's exactly what I wanted to do but idkk :/ I just feel like it's a waste with this silvertop already built. Unless I could sell it I guess idk how much it'd even sell for. Although the cash i spend boosting could go to an F. How much torque would the ST have? If I get this we can definitely meet up! Do you have a build thread or any pics? And your dad builds ae's that's sick!
One of the main things I'm worried about is the "tubbed" bay. I love the idea but I'm just not sure where I'd rearrange everything in the bay if there's even much. Just fluids and stuff I can remember off the top of my head.
Anyways should be looking at it this week PO's coming back from a trip, im excited and nervous still scared on how long itll take to finish this project and how much its gonna cost. Anymore help and tips for when I look at it are gladly appreciated. Thanks so much for all the help so far guys I REALLY REALLY appreciate it.
SlideSexy
Postby SlideSexy » Fri Jan 10, 2014 9:09 pm
Yeah bro, im in North Prov! You? I do have a log. Its nothing much at the moment. Around April it should be better. My dad has had alot of AEs hes doing this one serious.
The F20c is nice. Very very nice. MORE than enough power. I just wouldnt put Honda in Yota. ST could be worth sonething good if iti s running. You should try and make it run.
Abcdefranklin
Postby Abcdefranklin » Thu Jan 16, 2014 12:08 pm
Nice man! Right now I'm living in warwick! I checked out your log. You and your dad do all the work? Is there anything you guys can't do? Don't wanna be annoying but I know I'm gonna need help already.
Yeah I don't like the idea of another engine other than a Toyota inside the ae buy its always nice to think about.
Should be going to see the car this week PO just got back from his trip.
I just wish I could have someone who knows about ae's come with me just to make sure everything checks out. I just feel like ill build this entire car perfectly and some stupid **** will happen like the rear bumper won't fit properly or something haha. I guess I just wish I knew what an ae shell looked like haha
SlideSexy
Postby SlideSexy » Thu Jan 16, 2014 11:07 pm
Yes we actually do, do all the work. Besides paint lol. He mostly does the hard stuff, but i help. The one thibg i dont know about carsar e 20vs.. ive never even saw one in person.
When do you plan on going? I mightbe. Able togo. Withy ou.
I agree on Toyota engine in an AE. If upgrade to another engine.. ill spend whats needed to go Beams 3sge
Abcdefranklin
Postby Abcdefranklin » Sat Feb 01, 2014 9:30 am
@slide I should be looking at the car on Monday. And that beams engine is sexyyyy
